Minneapolis Moline Tractors Discussion Forum
M670-LP Hot under the Hood
shinnery
06-14-2006 13:02:07
This post is to inform all interested in a problem I had last year with my M670-LP. It all of a sudden got hot under the hood and flames were rolling out from under both sides. Lucky I only had the vapor on at the time but it still got hot reaching in to shut off the Vapor Valve. My tractor has a piece of rubber flex hose connecting the LP Gas Filter and the Vaporizer and it is within 6 inches of the exhaust manafold. I guess due to heat and old age this hose ruptured and was letting propane vapors spray on the exhaust manafold, which immeadiately caught fire. I don't know how big a torch I would have had If the liquid had been on. I don't know what other models have rubber flex hoses near the engine but you may want to check yours. I am going to build a heat shield to mount between the exhaust manafold and sensitive hoses to prevent some of the heat damage. Still 40+ year old hoses need to be checked. Bryce
_____ _____ _____
No trees were killed in the creation of this message. However, many electrons were terribly inconvenienced.
UBU-LP, M670-LP, 445N-LP, 445E-LP JD 440ICD/831
LW
06-16-2006 20:45:51
 Re: M670-LP Hot under the Hood in reply to shinnery, 06-14-2006 13:02:07
YOu might want to replace that rubber flex hose with copper and flare fittings.
shinnery
06-17-2006 15:50:33
 Re: M670-LP Hot under the Hood in reply to LW, 06-16-2006 20:45:51
I went to my local hydraulics shop and had a new hose built. Currently it has several layers of Aluminum foil wrapped around it. I plan on building a heat shield for that area whenever I get my plasma cutter opeational. Looks like I can use the vaporizer mounting bolts to secure it.
Bryce
The REAL Kelvin
06-14-2006 18:51:22
Thanks for that post. We have to be careful around these nearly 40 year old tractors.
It reminds me of the time a bird nest next to the exhaust manifold in one of the 'project' tractors caught fire. Only took a few minutes running time to ignite. And of course its in a shed next to my shop and the battery is dead. (I switched it of when I saw smoke.) It was hard to put out with a fire extinguisher too.
