Minneapolis Moline Tractors Discussion Forum
5-star speeds
Chris Sublett
06-11-2006 09:39:19
I was wondering if anyone had the speeds listed for a 5-star universal with 38" tires. I need to no high and low speed in all 5 gears. Thanks Chris
J Wuertrz
06-14-2006 07:42:22
 Re: 5-star speeds in reply to Chris Sublett, 06-11-2006 09:39:19
What is the loaded radius? Is it the tire size?
Chris Sublett
06-14-2006 06:15:25
Thanks fellows, this will help. Chris
Chris Sublett
06-13-2006 07:17:26
I need a gear just a little faster than first. I think third low is going to work but I was wondering if there was any lit. on the speeds. Thanks Chris
Kevin Moschenrose
06-13-2006 22:21:15
 Re: 5-star speeds in reply to Chris Sublett, 06-13-2006 07:17:26
Chris here you go!
UNIVERSAL MODELS with 13.6 x 38 tires
High range: 1st 2.93 mph
2nd 4.48 mph
3rd 6.82 mph
4th 10.58 mph
5th 16.21 mph reverse 4.48
Low range:
1st 1.54 mph
2nd 2.35 mph
3rd 3.58 mph
4th 5.55 mph
5th 8.51 mph
reverse 2.35
STANDARD MODELS with 14 x 26 tires.
High range:
1st 2.84 mph
2nd 4.37 mph
3rd 6.61 mph
4th 10.25 mph
5th 15.71 mph
reverse 4.37
Low range:
1st 1.49 mph
2nd 2.28 mph
3rd 3.47 mph
4th 5.38 mph
5th 8.25 mph
reverse 2.28 mph
I hope this helps you out! Signed the 5* gooroo!
Captainhookerus
06-12-2006 21:29:27
Chris it is a little hard to get the exact speeds,unless you know the loaded radius and engine RPM. Here are the ratios. HIGH LOW
1 81 154
2 53 100
3 34 66
4 22 42
5 14 27
Captainhookerus
06-13-2006 16:40:26
 Re: 5-star speeds in reply to Captainhookerus, 06-12-2006 21:29:27
(loaded radius X 2 X 3.1416) x (rpm/ratio x 60) / (5280 X 12) This formula should give you MPH
