Minneapolis Moline Tractors Discussion Forum
MF 97 cooling system problem
Hillfarmer
06-11-2006 04:51:22
I have a MF 97 diesel with a cooling system problem. Every little while it spews antifreeze out the radiator cap. Someone told me it needs the water pump rebuilt. The water pump does not leak but the shaft is lose. Can this be the problem or do I have something more serious wrong?
Hillfarmer
06-15-2006 06:37:47
 Re: MF 97 cooling system problem in reply to Hillfarmer, 06-11-2006 04:51:22
Removed the thermostats and found that some one had welded the holes shut!
I checked with Agco, NAPA, and CarQuest and the gaskets are not available.
Curt Cooke
06-12-2006 06:59:57
I would repair that water pump and check the thermostats. If the thermostats are not drilled, drill them. With those two things attended to, you should be OK. My 97 will still spit out a little once in a while during the warm up period; that's just the way it is.
Alan K
06-11-2006 10:11:37
I had a similar problem with my ZA, did the same thing. I believe i ended up drilling a small hole in the thermostat. It allows more circulation. Not sure if that is your problem, but might be a place to check.
