Minneapolis Moline Tractors Discussion Forum
hydralic problem on G1355 White
Thomas Tysver
06-10-2006 16:07:15
Having trouble with the hydralics on a G1355 White. No hydralics and no power steering. Does have steering when the RPM's are put to it. The mechanic in town says that the pump is fine but for some reason is not putting out the volumn. He had the pump apart and didn't find anything wrong. Anyone have an ideal what could be wrong or what direction we should be looking in? Thanks Tom
Thomas Tysver
06-20-2006 16:41:58
 Re: hydralic problem on G1355 White in reply to Thomas Tysver, 06-10-2006 16:07:15
Passed your information along too the mechinc in town. Got back into town today finaly thinking he would have it up and running, but no. He's tried about everything and talked to a few MM people but not having any luck. He's stumped any information on what path to send him on would be appreciated. Thanks Tom
jack blessing
06-10-2006 17:36:47
the unloader valve could have a very small piece of metal etc. in it. easy way to tell is after turning off engine you should hear a click in the unloader valve aprox. 3 to 5 seconds later. that type pump will not build pressure if thats the problem. eaven something the size of a pin point will cause this problem.
DuW806
06-10-2006 16:29:54
Is your hydralic filter plugged? Last winter my loader tractor did the same thing I found ice in the filter put in new filter and works fine. If this isnt the problem for you I would also check if there is a bypass valve and if it is stuck open or partially open. Just my 2 cents. good luck.
