Minneapolis Moline Tractors Discussion Forum
Jet star ampli-torc
Matt Mullen
06-06-2006 15:50:11
Fellas, I need some advise on what seems a common problem. I split my jet star to replace a bad clutch and try to repair the Ampli-torc which has not been working for 10 years. I have some groves worn into the carrier from the plates of the ampli-torc but all parts look o.k. and after some adjustment it will snap in and out. I am getting some advise that I should try to replace it because when shifting from high to low the groves may not let the plates release. The springs that hold the rollers in the cage cam were all disentigrated and that is what I think is why it will not move when in low. The shaft from the Ampli-torc going into where the rollers ride has a little wear but that is all that looks bad with that assembly. Am I folish to limit the repairs to only the cage bearing and cam by replacing the springs and rollers. He is talking $350 plus for just the carrier and Hub.
JK2
06-07-2006 06:29:47
 Re: Jet star ampli-torc in reply to Matt Mullen, 06-06-2006 15:50:11
I have brazed the grooves in the tabs then filed them smooth. The brass seems to hold up very well. You have to be careful to file them to the original contour and size so the plates aren't damaged.
The other usual problem that you don't mention is that there are grooves on the ramps where the rollers run where they normally stop. You can smooth them with a flat narrow hand stone but it takes quite a bit of time. If you don't remove the grooves, the rollers will have atendancy to stop in the grooves and not grip the center hub tightly & then slip.
John
Kevin Moschenrose
06-06-2006 23:02:47
Matt, Ampli- Torcs are expensive to work on. Yes he is right it does need to be smooth in order for the plates to move and work like they should.
