Minneapolis Moline Tractors Discussion Forum
Moline Starters
Jerry Cent. Mi.
06-04-2006 14:00:42
Is the starter and bendex for a U and 403 G interchangeable? Thanks Guys
jcwp
06-09-2006 15:54:00
 Re: Moline Starters in reply to Jerry Cent. Mi., 06-04-2006 14:00:42
I once ruined a 403 starter by using Naval Jelly on the rust--deteriated the insulation. So I put the UTS stater motor on the 403 bendix. I had to drill a tapered hole on the other side of the bendix housing to accept the tapered hold-in bolt. It all ligned up and works well. I use twelve volts on the six volt starter--spins fast--starts quickly and has lasted ten years. Jim
mnm
06-06-2006 05:37:30
you can put the 403 starter on the early u by putting the u bendix on the 403 starter then you need to grind the opening on the starter nose to let the starter slide back into position it hits the u flywheel. To put it on the newer U or UB you will need to change them to the old U ring gear which requires some machine work or you can use the 403 crankcase and put the 403 ring gear on the U or UB flywheel it fits right on them but then you will need to grind the rearend housing out a little as the 403 ring gear is bigger around than the u or ub
Flamefighter
06-05-2006 17:10:11
I agree with Kelvin. We have tried to put 403 starters in U's before and found differences. Bendix usually the same, but some were bigger around where you tighten the mounting screw down. Can't recall but just know we alway had trouble trying to interchange the two.
Kelvin
06-05-2006 06:59:27
Yes, no, maybe. The Us used 2 different starters and there is a difference between bendixes and flywheels. the 403 starter I got from Wendell Everett when I put a 403 in a UTS was a great big thing compared to a U starter. I have seen U starters on 403s but I don't know what bendix they used.
I know that doesn't answer your question, but its something to be aware of.
