Minneapolis Moline Tractors Discussion Forum
585 Turbo Pressure
Kyle S
06-02-2006 21:52:05
What was the stock Boost pressure of a 585 Diesel?
How much could it handle?
lee r
09-26-2006 22:12:28
 Re: 585 Turbo Pressure in reply to Kyle S, 06-02-2006 21:52:05
i run 2 of these engines 1 in a 1355 diesel to farm with ,1 in a puller ,the puller runs 50 plus pounds boost ,have had no problems except overdrive wont hold in roadgear i do all my own engine building where i live on the farm ..
jackpot 2655
07-17-2006 20:32:27
hi i have an oliver 2655 with a 585 engine.this spring the oil pump drive failed.the engine is ok it was caught in time. i would like to turbo charge this engine if it can be done nicely.i also need the external oil pump and all the things needed to convert it over .i bought the tractor at stilsvile auction,Stilsvile IN in 1990
DoddsRacing
06-06-2006 08:43:36
We are building a 585 to pull and have been told if we run stock cylinders ,with out sleeves ,not to go over 20,lbs boost or it will crack a jugs.
J Schwiebert
06-03-2006 06:09:24
Remember the turbo was only available as a field kit as an altitude compensator. I don't think it was too much.
Kyle S
06-03-2006 09:41:03
 Re: 585 Turbo Pressure in reply to J Schwiebert, 06-03-2006 06:09:24
Thanks for the Answers
BMG1
06-03-2006 07:33:23
J,
That may not necessarily be true. There was a serial number series for a TD585-6 Turbo Diesel engine (G1350 and A4T-1600) - serial number began with 467.
I've never run across a spec for boost pressure on these engines. I wouldn't expect it to be very high though.
Brian
