Minneapolis Moline Tractors Discussion Forum
Blown head gasket, the first time out with new U
moli
06-02-2006 15:22:05
Oh well it happens..gonna torque er down with new gaskets a little harder this time..say, 150 to 170 ftlbs..Think that will work??Its not a copper gasket, got fire rings..4.8 X 6.125 bore n stroke runnin 4210 heads..Would like to put somthin on the gasket to help seal er up but dont know what to use,got any suggestions?.....STEVE
duner53
06-03-2006 22:09:30
 Re: Blown head gasket, the first time out with new in reply to moli, 06-02-2006 15:22:05
i have the same but with 4232 heads and i use 670 head gaskets with coppercoat on them torqued
to 175 or 180 and do not have any problems.
good luck
MOLI
06-04-2006 10:20:46
 Re:Hey duner53, Blown head gasket, the first time in reply to duner53, 06-03-2006 22:09:30
Hey duner53..Is that spray on high tack copper coat or the brush on kind??
mnm
06-02-2006 19:46:24
All the sealer in the world wont keep a head gasket from blowing out the compression. The fire ring that is crimped in the gasket has to do that. Let me guess you are using the lubbock gasket with the crimped in fire ring right?
moli
06-03-2006 13:09:16
 Re: Blown head gasket, the first time out with new in reply to mnm, 06-02-2006 19:46:24
Nope,its a gasket with seperate fire rings..I plan on usin a higher torque on the head studs to seal er down..Some people paint,some people use copper coat and some use nothin on the gasket itself..I would like to get an opinion on coatin the gasket if need be....I used a lubbock copper on my cockshutt 50 at 12:1 compression and used the wire around the cyls and that worked good at sealin the compression but still had a small anoyin oil seepage .Thanx...
answers
06-02-2006 17:36:38
With what you wrote I have been able to surmize that you should be running around 9.9:1. Have you ran a compression test? And where are you at?
moli
06-02-2006 19:25:07
 Re: Blown head gasket, the first time out with new in reply to answers, 06-02-2006 17:36:38
No, i havent done a compression test and i live in NY...
dan791
06-05-2006 05:34:13
 Re: Blown head gasket, the first time out with new in reply to moli, 06-02-2006 19:25:07
Where do you pull your moline in NY?
MOLI
06-05-2006 12:00:51
 Re: DAN791 Blown head gasket, the first time out in reply to dan791, 06-05-2006 05:34:13
Dan791,I pull mostly in central NY...
MOLI
06-05-2006 11:57:54
