Minneapolis Moline Tractors Discussion Forum
Mm UM-5 mower
jossette
05-10-2006 15:14:10
third party image
Looking for the plate on the back (outside) of the grass board. Anyone have one laying around.
# 3 in the pic.
Thanks
Bog
05-17-2006 09:52:48
 Re: Mm UM-5 mower in reply to jossette, 05-10-2006 15:14:10
I talked with Lester, you got the last guage wheel out there. He said it would probably be a cold day before he found another. But he is working some stuff for me. Thanks for the help. Where in Minnesota are you from. I live on the River just south of the metro.
jossette
05-21-2006 17:01:52
 Re: Mm UM-5 mower in reply to Bog, 05-17-2006 09:52:48
third party image
put it together today
have to scratch the bar and paint it yet,
jossette
05-17-2006 13:10:49
I am in a little town called Waldorf. Southern part, south of Janesville and southwest of Waseca.Its to bad I took the only one, They're are a nice item to have. Good luck with your findings with Les. He is good.
Bog
05-15-2006 05:04:24
I can probably make a copy of mine then cut you one with the plasma cutter. I have to fix mine up a bit anyway. There is not much to it so it could be quite easy to make one. Did yo replace your guards on the bar. If so where did you find them and what did you use. Let me know.
jossette
05-15-2006 18:02:31
 Re: Mm UM-5 mower in reply to Bog, 05-15-2006 05:04:24
I figured on no one having one so I made a cardboard template and had a guy make me a couple.
The gaurds are standard ones you can get at TCS.
If you needs parts for it, call Lester Wenzel in New Richland Minnesota. He got me everything and then some.
thanks for the reply.
Bog
05-16-2006 05:00:29
 Re: Mm UM-5 mower in reply to jossette, 05-15-2006 18:02:31
What are you using for a grass board? Mine is toataly gone. Did Lester have one of them? Also what tractor are you using it on? Im trying to find someone to give me mesurements for the foot pedal for an R.
jossette
05-16-2006 15:12:54
 Re: Mm UM-5 mower in reply to Bog, 05-16-2006 05:00:29
I made my own board out of 1x8 oak. Not to hard with a band saw. Getting the angle you want will depend on where you put the notch in the baord. I have a farmall 400 and do not have a foot pedal on it. You should call Lester and see what he can do. He found a depth gauge wheel for the end of the bar to get it off the ground. Well worth the $60.. He is a retired MM dealer and can find about anything. He does have a pitman by the door if you need one complete.
