Minneapolis Moline Tractors Discussion Forum
hydraulic/transmission fluid for GVI
equally confuse
05-09-2006 15:46:43
I have a GVI LP, can"t for the life of me find a dipstick for the transmission. Found a dipstick for the hydraulics, I think behind the seat. I even have the reprint service/repair manual. Are the hyd. and trans. the same? Thing has a cab on it and this makes things more difficult to find and service. Thanks.
david schrock
05-11-2006 12:26:31
 Re: hydraulic/transmission fluid for GVI in reply to equally confused, 05-09-2006 15:46:43
in all our old moline hyd systems we have been using a good quality hy-tran fluid like all the new tractors use for combined trans and hyd functions. Works great no problems
Kelvin
05-09-2006 19:16:15
The fluids are separate. That dipstick behind the seat would be for the hydraulics. Sounds like a type 'E' system to me.
The transmission fluid level is checked at a plug on the right hand side of the transmission, probably near the brake pedals. To add transmission fluid the older Us had a 3-bolt plate over a hole in the transmission top, not too far back from the shifter. Your GVI should have something similar or else a pipe plug in the cover.
The Old Us used 140wt in the transmission and I am unsure of what hydraulic fluid your GVI would use.
