Minneapolis Moline Tractors Discussion Forum
Stripping weight from a U
danny791
05-09-2006 06:49:40
I have a U that I pull and it weighs 4900 with a 200 lb driver. How can I lighten it up more? Any help would be appreciated.
Jerry Cent. Mi.
05-10-2006 16:41:12
 Re: Stripping weight from a U in reply to danny791, 05-09-2006 06:49:40
The PTO can be removed but you will need to reduce at least 355 lbs to get down to the next lower class. Why not add 150 lbs and go up to the 5000 lb class. They pull better in the heaver class anyway.
dan791
05-11-2006 05:17:48
 Re: Stripping weight from a U in reply to Jerry Cent. Mi., 05-10-2006 16:41:12
I am looking to strip enough weight to be able to put three hundred out on the front weight bracket. We only have 5000 classes and up. My problem now is my tractor has plenty of power but lifts the front end quickly in the 5000.
Barnheater
05-09-2006 15:08:48
What all do you have done to it now to get it to 4900lbs?
dan791
05-10-2006 06:03:58
 Re: Stripping weight from a U in reply to Barnheater, 05-09-2006 15:08:48
No fenders, belt pulley, foot platform. Pressed steel rims. THats about it.
Barnheater
05-10-2006 18:42:42
 Re: Stripping weight from a U in reply to dan791, 05-10-2006 06:03:58
Get a magneto & remove the starter,generator& battery. Pressed steel rims off of a "Z" are very light. Light weight tires such as armstrongs, if rims & tires are good mount them tubeless. 15" front rims with 400x15 tires, also tubeless if possible. Light weight hitch but strong enough. If the bank account allows aluminum oil pan & transmission lid. Drop to 5gal of oil in rearend if your just going to pull it. Remove everything thats not needed to go pulling. Also the steering shaft can be made out of aluminum.
