Minneapolis Moline Tractors Discussion Forum
Moline plows
farmerjosh
05-08-2006 11:10:48
I have several moline plows...they seem to be my weakness...and I just bought 2 more...one is a 3 bottom hydraulic lift plow that is partially restored...can anyone tell me the correct paint scheme on one of these. O also bought a 4 bottom 3 point pipe frame plow with the MM plug in the end of it...what color should this be and where can i find coulters for it....also is a 4 bottom rare...I already have a 3 bottom but never saw a 4 before
tourbob302
05-21-2006 05:47:16
 Re: Moline plows in reply to farmerjosh, 05-08-2006 11:10:48
Iam Looking for a 3 bottom semi mount mm plow for a <
br>U302 if you run across one thanks, bob
JK2
05-12-2006 05:16:41
My dad had a 1952 2 bottom 14" hydraulic lift plow that was purchased new by our neighbor. My nephew still has it along with the 1952 RTU. It has the original paint on it and is MM red with yellow wheels (including the hubs). I had a 4 bottom 14" hydraulic lift plow that was purchased new with my UB diesel by the brother in law of the neighbor that had the RTU. It was also painted red with yellow front wheels. The rear wheel was red, but it may have been replaced at some time. The new hub parts I had for the rear wheel were yellow.
John
RRs MMs
05-11-2006 11:31:45
I have 2 two bottom and 1 three bottom hyd lift plows. They are mostly rust colored right now but as far as I can tell from whats left, the rims and wheels were prarie gold and the rest of the plow is MM red. I got these plows from 3 different people and each one said that was the way they were made.
Bruce S. ILL.
05-11-2006 09:40:40
I done some trading about a month ago and came up with a 4 bottom 3 pt MM plow model M1400. Did a little plowing with it the other day with my M602. It has almost no paint left on it. It looks like the frame and tubes were red with the MM in the cast part yellow. The beams appear to have been yellow on the front and red on the back and sides. The coulter stems are blue but when I sanded on them they appeared to be red underneath. The mast where the upper link connects also looks like it was blue but also looks like there could be some yellow in spots. I have never seen blue on any MM equipment but I don't know much about MM impliments. Mine may have been repainted. I really have no idea of what is original, this is how mine seems to have been painted. You can find some info. on pull type plows if you search past posts.
