Minneapolis Moline Tractors Discussion Forum
UTU freeze plugs
jwp519
05-07-2006 15:38:25
Got a full set of "UTU freeze plugs from Welters - 8 altogether (4 half-dollar size, 4 quarter size) and am trying to identify all the necessary locations for replacement, but only found 2 so far. Any help would really be appreciated.
GaryK
05-08-2006 10:35:09
 Re: UTU freeze plugs in reply to jwp519, 05-07-2006 15:38:25
Curt is right. There are two on each head and two on each cylinder block. The heads are on the front and back. The blocks are on the front and back also. From my experience, this can be a real problem if one that ends up between the heads or blocks leaks!!!
Curt Cooke
05-08-2006 06:13:55
There should be two in each head. They are on both ends (not sides) of the each head. There should be 2 in each jug, I think one on each side. If you have a one piece head and one piece block, ignore this as I have no experience wiht the one-piecers.
