Minneapolis Moline Tractors Discussion Forum
main and rod torque spec
moli
05-05-2006 18:09:11
Ive seen posted here the rod and main torque specs of 110-120 ft lbs front main and center and rear main 75-80 ft lbs..these were said to be for a U...Are these correct? my manual says...95 ft lbs front and 65 ft lbs center and rear main..What should i use when building my 448cid U ?? Steve
GaryK
05-08-2006 10:40:18
 Re: main and rod torque spec in reply to moli, 05-05-2006 18:09:11
I have the service manuals for the U tractors. The earlier ones used a "KEF" engine and the later ones used the "split block" 283-A4 engine. Both, I believe, had 283 cubic inches. If you can tell if you have one of these engines, I can get you the torque specs out of my manuals.
