Minneapolis Moline Tractors Discussion Forum
G1000 LP is sluggish
Curtis Keiser
04-28-2006 13:23:06
I have a G1000 LP that is dead and sluggish under a load. The engine mechanically is good so I am looking at the governor or LP components as being the problem ? It will develop full RPM's and runs smoothly but does not respond very well when you start putting a load on it. It does even begin to develop the power it should.
Any thoughts on trouble shooting would be appreciated.
Singer Farms
05-03-2006 06:58:18
 Re: G1000 LP is sluggish in reply to Curtis Keiser, 04-28-2006 13:23:06
After our G1000 sat for the winter, we had a similar problem. We started to tear down the evaporator for the LP and noticed mud wasps had filled in the breather hole on the front side of of the evaporator. After it was cleaned out, the tractor ran fine.
Roger H
04-29-2006 10:28:37
I have a Case 930 that is doing a similar thing. Does your fuel system frost up anywhere? if so, you have a restriction at that point. Do you have the valve on the tank open far enough?
oneyedog
04-29-2006 09:59:28
Are you running on vapor? If so you need to open the liquid valve and close the vapor valve for doing heavy work. These engines start well on vapor but don't make any power unless running on liquid. Hope this helps.
