Minneapolis Moline Tractors Discussion Forum
80-90 gear oil in hyd.
Keith W from Pa
04-23-2006 16:28:58
I had to add some hydralic oil to a Jet Star11 and I picked up the wrong oil and put about 2 qts. in before I discovered what I done. Will this have to be all drained and refilled? Keith in Pa
Kevin Moschenrose
04-24-2006 22:33:48
 Re: 80-90 gear oil in hyd. in reply to Keith W from Pa, 04-23-2006 16:28:58
I am pretty sure this won"t hurt it, but on the other hand I think I would just drian it before it gets though the whole system. Even though the couple of gallons now that you will be out in changing it at least now you will be peace at mind. Might as well change the filter while your at it since if your going to drain it might as well replace it too and start fresh all the way around.
