Minneapolis Moline Tractors Discussion Forum
What MM tractor is this out of?
Kenny F.
04-16-2006 16:06:12
third party image
I have a set of four of these rods and pictons.....I'm pretty sure they are out of some MM tractor...but I don't know MM that well since I'm a farmall guy...
Piston: 3 5/8", casting no. RE 255
Rod: Casting number RE 307 MM Made in USA
Can anyone identify the specific model?
Thanks
Kenny
ILL John
04-17-2006 18:59:16
 Re: What MM tractor is this out of? in reply to Kenny F. , 04-16-2006 16:06:12
The rod #s are for the 206 used in the ZA-ZB series, the piston casting # I don't find in my catalogue but they are for the 206 also. The 206 uses the same cyl, 3 5/8 bore as the R, "EE", and Z, "RE" engines. There were 2 casting #s for the cylinders, RE 101 and 10A1462.
Chuck S.
04-17-2006 15:16:55
They are Z piston sand rods. An R used alu. pistons with a raised step.
J.Wondergem
04-17-2006 13:19:29
Both the model "R", and the Model "Z" had 3 5/8 bore.
