Minneapolis Moline Tractors Discussion Forum
5 star engine question
Flamefighter
04-12-2006 18:39:53
Hi guys, I have a 1958 M.M. 5 star with the 283E engine. I am going to take the blocks and 4232 heads off a 336 irrigation engine, and put them on the 5 star. My question is does the 283 cam have the same lift and duration as the 336 cam? I dont have any of the cams out yet so don't know the part numbers of them. If I can get by with leaving the 283 cam in would save tearing it down, but want the correct duration for the bigger cubes. Any one know? Thanks.
flamefighter
04-17-2006 17:38:22
 Re: 5 star engine question in reply to Flamefighter, 04-12-2006 18:39:53
Thanks guys I'll give them a try.
big bore 5 star
04-15-2006 13:10:40
add a g crank while you are in there
flamefighter
04-15-2006 19:09:07
 Re: 5 star engine question in reply to big bore 5 star, 04-15-2006 13:10:40
SOUNDS GOOD ADDING A G CRANK (403) BUT THAT WOULD GIVE IT ONE INCH MORE STROCK. HOW WOULD THAT WORK WITH 336 BLOCKS? I have some 403 cranks.
Chuck S.
04-17-2006 15:27:12
 Re: 5 star engine question in reply to flamefighter, 04-15-2006 19:09:07
Call Welters they have some pistons that will make it work.
Chuck S.
04-13-2006 16:36:11
The cam in the 283 should work ok. The lift and duration is almost same.I would sugest that you cut the ring grove out at the top of cylinder. When you move cylinders and pistons the top ring may strike ridge and cause damage to pistons and rod inserts.
flamefighter
04-13-2006 10:14:41
The irrigation engine is a 336A 4A newer sytle.
