Minneapolis Moline Tractors Discussion Forum
Damaged Cylinder Wall
Fungus
04-05-2006 15:34:17
After pulling the head on my KTA to get a closer look on things I discovered that one of the cylinder walls was damaged. It appears to a be a gouge or a tapered chip out of the side if I am explaining myself correctly. The total area is about 1" by 1".
Repairable, new block, insert sleeve and rebore? What should I do? I'm in unchartered waters.
Kevin Moschenrose
04-07-2006 00:15:44
 Re: Damaged Cylinder Wall in reply to Fungus, 04-05-2006 15:34:17
I agree with George on this a sleeve repair would be the way I would go as well. Besides it's not your going to go farming with it day in and day out.
Kevin Moschenrose
04-06-2006 09:30:34
It kind of sounds like a rod may have broke at one time or another. Where is the damage locatated on the cylinder at? Top or bottom? and how far from the end?
Fungus
04-06-2006 15:15:50
 Re: Damaged Cylinder Wall in reply to Kevin Moschenrose, 04-06-2006 09:30:34
The damage is located approximately 3 inches from the top of the cylinder. I have no idea when it last ran or what was changed, but the bottom end is spotless.
Any ideas on repair or just replace the block?
Kelvin
04-07-2006 14:44:52
 Re: Damaged Cylinder Wall in reply to Fungus, 04-06-2006 15:15:50
Take the block to a good automotive machine shop. They should be able to tell you how to fix it. I've had good results with sleeves before.
george md
04-06-2006 22:03:42
Sounds like a sleeve would fix the problem . Either 1/8 or 3/32 wall depending how much damage there is . Sleeving is a good repair , I do many of them .
george
