Minneapolis Moline Tractors Discussion Forum
585 block
New MM Puller
04-04-2006 07:00:32
i just bought a 1350 diesel that has a replacement block in it. they claim that the old motor threw a rod when they turned the screw a little too much. supposedly the internal oil pump couldnt push enough oil if the juice was put to her. so now it has an ugly conglomeration of an external oil pump hanging out the side in front of the hydraulic pump. has anyone ever seen this before??
jackpot 2655
07-17-2006 20:49:53
 Re: 585 block in reply to New MM Puller, 04-04-2006 07:00:32
hi i got a oliver 2655, the oil pump just failed.i would like to convert it to an external
oil pump
Mopower
04-04-2006 12:02:42
Many 585 engines were recalled and fitted with an external oil pump. Later ones came equipped. Earlier internal pumps were ok for a while but couldn't take extended high RPM use on the new 585 engine. This gave 585 a bad rap. Clearances in rebuild manuals were wrong too, causing a few seized ones. Cool design, but a few bugs with them.
