Minneapolis Moline Tractors Discussion Forum
Model #
John London
03-31-2006 05:59:59
I found a MM that has most of Model tag worn off by a hose. The only number on the tag for the model looks like it starts with a 5. The s/n is 29502119. The number stamped on the block is 10A2308 and number stamped on head is 10A4232. Its a big 4 cylinder tractor with 18x34 tires. Has 3pt with dual hydraulic hook up, factory L.P. converted to gas, draw bar seperate from 3pt that is attached to belly. Photo archives has a picture of a 504 that looks similar except this one does not have rounded fenders like the one in the archives. Price seems reasonable but would like to know what It is. Just looking at it I would estimate it to be 8,000 to 10,000 pounds. Any help? Thanks!!!
John London
03-31-2006 08:21:27
 Re: Model # in reply to John London, 03-31-2006 05:59:59
I will have to check the SN. Could have read it wrong. I looked at the M670 photos and it sure looks similar. It sounds good, looks solid and do not see how I can not take it for $1,500. Thanks for the assistance. There aren't many Molines in this part of the country but I have been thinking I need one for quite a while. Thanks again!!!
JK2
03-31-2006 07:34:03
Are you sure the 3rd digit isn't a 9 instead of a 5? 29902119 is a serial number for a 1966 M670 gas or LP. The 10A4232 heads would be correct for that tractor.
John
