Minneapolis Moline Tractors Discussion Forum
445 power steering sleeve
Gary Hilkemann
03-27-2006 11:34:32
i pulled the sleeves from my 445 and the "o" ring's and backing washers (leathers) are pretty flat. i also noticed some pitting in the sleeve itself, plus my parts book shows another "gasket" on the end of the sleeve but i dont see one or where it goes for sure. can i hone these sleeve's or must they be replaced, and should both sleeve's come out of the bore pretty easy?
thanks,,,,Gary
Curt Cooke
03-28-2006 06:58:51
 Re: 445 power steering sleeve in reply to Gary Hilkemann, 03-27-2006 11:34:32
The sleeves don't always come out easy. The 10A6312 gasket is available from Welters and once you have it in your hand you'll probably have a better idea of where it actually goes. I wouldn't feel bad about running a hone through there, the O-rings and backing rings ought to be able to compensate for anything you can take out with a hone.
