Minneapolis Moline Tractors Discussion Forum
Identify Between MM.BF and BG. Difference
Dan Duval
03-26-2006 21:01:53
Trying to identify my tractor. no tag or stamped by pedals. shifter on right side, 4 speed. Steering column of left side with inditation under gas tank. wide front end, sits up high, head lights behind gas tank. six lugs on back tires.has hydraulics. not computer savy enough to put picture up on network.can you point me in the right directon. maybe between 1950-1955 hercules engine. Mannford,ok.
Dan Duvall
03-29-2006 21:20:47
 Re: Identify Between MM.BF and BG. Difference in reply to Dan Duval, 03-26-2006 21:01:53
Kelvin,Thanks for your input. two things I left out. from the drivers seat.same distance to both back tires.By feet pedals,a square bar runs across frame. behind seat on right side. high step. by your e-mail this may be an BF. thanks Dan Mannford OK.
Kelvin
03-27-2006 07:06:11
Most likely its a BF as you didn't mention it being offset. BGs are offset like a Farmall Cub and the steering shaft on a BG goes down the right side of the engine.
