Minneapolis Moline Tractors Discussion Forum
MM G900 Diesl Questions
ddavid smith
03-26-2006 16:24:32
i recently purchased a g900 diesel from a guy and i don't know whether to fix it or get rid of it. Serial#is 33101931 which is the 15th from the last one in 1969. it has the optional 3 speed transmission, duals, adjustable wide front, 3 pt. but the arms are gone. Sheetmetal is pretty straight, no grill. the owner used it to pull a roller for a racetrack they said it started running bad and it died i haven't tore it down yet im guessing a fuel problem i don't know is there any interest in it the way it is or not i live in west central illinois. im either going to fix it or sell it the way it is. Roosa Master pump on it and the block numbers are 10A2428. thank you
Luke Miller
03-31-2006 16:41:18
 Re: MM G900 Diesl Questions in reply to ddavid smith, 03-26-2006 16:24:32
I may be interested in the tractor in the condition it is in. I run field for Case IH in western illinois. I may be interested in looking at it.217 412 0001
shannon from ohio
03-26-2006 17:14:08
Check for water or contaminants in fuel BEFORE doing anything as this may be the problem?? Injector pumps as you probably know are NOT cheap!
