Minneapolis Moline Tractors Discussion Forum
hey mopower got a new toy
madmatt
03-23-2006 17:31:55
got a nice rtu from my old boss for helping him out ina jam. tin is straight some one hacked around the exhaust a little bit and notched the side panel probably for an altanator both spots are real fixable carb needs to be gone thru and valves need to be adjusted and painted the right color I wat to go play at the pulls and see how it does . is there a meeting this weekend? let me know mm
GaryK
03-24-2006 06:14:44
 Re: hey mopower got a new toy in reply to madmatt, 03-23-2006 17:31:55
madmatt:
Congratulations on your tractor. Just wondering how you intend to fix the cuts around the muffler? My UTs has had some minor cutting done around the muffler. Thought about trying to weld in a piece and recut it to correct size, but would require some body filler. Concerned about heat in this area from the muffler. Mine is only cut a little, so actually thought about just smoothing out the cuts that someone else did and just leave it a little larger hole than original. Any ideas?
Thanks for any help.
madmatt
03-24-2006 19:13:19
 Re: hey mopower got a new toy in reply to GaryK, 03-24-2006 06:14:44
I'll probably fill the hole with new metal and re cut the hole I think if you use good quality filler you should be safe I check and see what my paint/body shop supplier says after all it does'nt ruin the paint in that area from the heat and it does directly touch it either
