Minneapolis Moline Tractors Discussion Forum
605 Rod Length
MoInMinnesota
03-22-2006 16:45:09
I know this has been gone over time and again, but I'm looking to build a 605 diesel. I'm not looking at building a puller, just a farm tractor. I have been doing some investigating and have everything pretty well figured out except for the rods. I've heard of using rods from a Case, but from what one I don't know. I know the 605 rods can be used, but it's my understanding that they are to weak to handle much use.
Can anyone be of assistance here?
Thanks much!
Dieselbear
03-23-2006 03:55:24
 Re: 605 Rod Length in reply to MoInMinnesota, 03-22-2006 16:45:09
1070 Case rods
MoInMinnesota
03-23-2006 15:10:57
 Re: 605 Rod Length in reply to Dieselbear, 03-23-2006 03:55:24
Is there anything that needs to be done in terms of the journal width? Journal diameter?
What pistons do you run with this setup? Are there any modifications that need to be done to the wrist pin?
Thanks much for the reply
Mopower
03-22-2006 17:51:21
I would contact Henderson Power. He knows what rods work with what setup. M-M did make a tall block 605 diesel, but pretty rare. I am assuming you wantt o make a 504 diesel in to a 605 by swapping cranks.
MoInMinnesota
03-23-2006 15:13:50
 Re: 605 Rod Length in reply to Mopower, 03-22-2006 17:51:21
Basically making a 605 out of a 504. How do I get a hold of Henderson Power?
Thanks for your help,
Mopower
03-23-2006 15:21:33
 Re: 605 Rod Length in reply to MoInMinnesota, 03-23-2006 15:13:50
269-253-4018 for Henderson Power
MoInMinnesota
03-24-2006 06:40:14
 Re: 605 Rod Length in reply to Mopower, 03-23-2006 15:21:33
Thanks
