Minneapolis Moline Tractors Discussion Forum
power unit vs. GB crankcase?
jason34
03-21-2006 06:19:41
Can anyone tell me the difference between a 403 power unit crankcase and a GB crankcase? I plan on making a puller and wondered what benefit it would be to go with a GB over a 403? Thanks
Captainhookerus
03-23-2006 13:02:41
 Re: power unit vs. GB crankcase? in reply to jason34, 03-21-2006 06:19:41
Use a 5 Star or later crankcase and get rid of the set screw starter. Every thing will fit and you cand even drill the crancase for the GB oil filter.
mm1111
03-24-2006 05:44:22
 Re: power unit vs. GB crankcase? in reply to Captainhookerus, 03-23-2006 13:02:41
Do not use a 5 star or M5 crankcase they are the weakest of any of the 4 cyl they would break in stock applications. If you want to update use the 670 super crankcase it is the strongest and easiest to get the gear reduction starter for.
mm11111
03-21-2006 19:41:00
Early 403 engines have 1/2 inch studs in the center and rear main the GB crank case has 9/16 studs,dowl pinned maincaps and the gov hole area is heavier. It depends on how far you are pushing the engine if you are building a fairly large cube engine i would use the GB style crankcase. Late 403 power units have the same crankcase i believe it is a 10A9980 or 9890
jason34
03-22-2006 09:17:15
 Re: power unit vs. GB crankcase? in reply to mm11111, 03-21-2006 19:41:00
I plan on a possible 5.5x6.5 motor.
Harrold Rhodes
03-21-2006 15:52:14
A GB has the 403 engine
