Minneapolis Moline Tractors Discussion Forum
445 Ampli-torq help
Dan Zemcik
03-12-2006 18:45:15
Hi everyone..I have a 445 that I reciently bought...When I pull the lever into the low position..well nothing happens, no slip or noise it still pulls like in high range..Anything external to check without going inside to repair?
Thanks for any input!
Harrold Rhodes
03-13-2006 17:24:35
 Re: 445 Ampli-torq help in reply to Dan Zemcik, 03-12-2006 18:45:15
Another possibility is you only have low range Which could be caused by lugs gone off the drive plates and it won't shift into high.
Kelvin
03-13-2006 07:11:03
If it doesn't slow down by about half or slip seems like its not releasing the high side. Perhaps either the shift linkage is disconnected, the high side clutch plates are warped so much they don't release.
These are just a couple of possible ideas.
