Minneapolis Moline Tractors Discussion Forum
ZAU Weight
Lee Brown
03-11-2006 11:37:47
Can anyone tell me the weight of a ZAU? No fluid in the rear tires, but it looks like a very complete, solid iron machine! Thank you!
flame
04-04-2006 18:55:40
 Re: ZAU Weight in reply to Lee Brown, 03-11-2006 11:37:47
I pull a 1950 zau. With out fenders, weight brackets, wheel weights or wheelie bars, it weighs around 3800 pounds. I pull it in the 4000 and 4500 class. Have also won in the 5000 class a few times also against some pretty heafty farmall m's.
yonson
03-16-2006 17:12:13
Nebraska test of ZTU in Sept. 1940 lists weight at 4850#. Anybody know why it should be that much more than a ZA?
Mark H.
03-15-2006 15:16:48
My 52 Z #3775 with nothing on it, no hydr. pto or pully. pressed wheels 4 ply tires Pulls great in #4500 lb class
yonson
03-13-2006 09:40:36
Nebraska test data of May 1950 shows PTO & belt HP (36.2), presumably they were on the test tractor with weight listed as 3750#, who knows if actual or estimated? Hydraulics add lots of weight, for sure.
Jerry Cent. Mi.
03-12-2006 08:31:37
Mine weighs 3770# with the pto and little effort to remove extra weight.
Lee Brown
03-11-2006 20:23:36
Thank you!
ILL John
03-11-2006 18:07:45
My JTU/RE is basically the same thing as a ZTU, it has cast centers on the front and real, weighs #5500 with me on it, no fluid.
yonson
03-11-2006 12:03:39
Intertec Used Tractor Price Guide says shipping weight is 3600#, ZA Operation & Maint. manual says 3800#. I assume the difference is wet or dry.
Kelvin
03-11-2006 18:03:07
 Re: ZAU Weight in reply to yonson, 03-11-2006 12:03:39
That sounds a little light. I bet it is without belt pulley, pto or hyraulics.
My '38 ZTU weighs just over 4200 and Dad's ZB weighs close to 5,000 with fluid in the tires.
