Minneapolis Moline Tractors Discussion Forum
585 oil pressure
Eric Berglund
03-11-2006 05:37:42
I have a feshly rebuilt 585 that runs 45-48 psi oil pressure at 180 degrees f and 15w-40 oil.
When cold the oil pressure is as high as 53 psi.
My question is , should I bother to take off the oil pan and add a shim to the relief? It is an internal drive oil pump that can be adjusted at 3 psi per shim . What do you all think?
jackpot 2655
07-17-2006 20:58:42
 Re: 585 oil pressure in reply to Eric Berglund, 03-11-2006 05:37:42
hi i have an oliver 2655,the oil pump just failed
and iwould like to covert it to an external drive pump.can any one help me out?
Harrold Rhodes
03-12-2006 10:11:40
The first 585's had oil sprays in the bottom of the cyls to cool the pistons. This took a lot of oil. The company soon abandoned this idea and sent out a service letter on how to plug this off. Later blocks were cast without these coolers. You can plug these from the outside through the hole in the center bottom of the block. You could lose pressure through the seal on the can that holds the oil filter. Another problem with the internal driven oil pump was wear on the oil pump gear. In my opinion the 585 was not reliable until the oil pump was converted to external and the oil cooler was installed.
Molinegb
03-11-2006 06:10:54
My 585 runs alot higher than that. When it is cold it runs about 80 and after warmup drops to 70. It has been running for years like that since the motor was rebuilt.
Tim Dodds
03-12-2006 08:07:46
 Re: 585 oil pressure in reply to Molinegb, 03-11-2006 06:10:54
Ower 585 has about 70 cold and never gets below 65 hot even at idle. We run straight 30 wt.It has about 9 years on an overhaul.
