Minneapolis Moline Tractors Discussion Forum
Bigger motor in a GB
Roger Roemen
03-06-2006 19:55:38
Can I put a 425 block and crank and 605 jugs and heads in a GB? If so what kind of problems my I incounter? Also what is a stuck GIV diesel motor with the big pump worth?
Roger Roemen
03-07-2006 14:03:12
 Re: Bigger motor in a GB in reply to Roger Roemen, 03-06-2006 19:55:38
I misstated what I wanted to do . I will try to get this right this time. I want to put a 425 block (because of the small bell housing) in a GB. I would like to use the 605 crank, rods, jugs, heads and all on this block. Can this be done with reasonable effort and normal shop tools?
Barnheater
03-06-2006 20:20:04
A GB was a 4 cyl 403ci, gas or propane. A GBD was a 6cyl 425ci. diesel. The 425 was a 5in stroke and the 605ci was a 6in stroke.
Barnheater
03-06-2006 20:29:24
 Re: Bigger motor in a GB in reply to Barnheater, 03-06-2006 20:20:04
If you have the GBD with the 425 in it I would get blocks and pistons from a 504 and go that route. Increase the bore to 4 5/8, 504ci, just bolt it together.
