Minneapolis Moline Tractors Discussion Forum
BF Model R Governor
Dreydan
03-02-2006 12:21:27
Does anyone have a picture for the linkage from the throttle to governor and governor to carburetor. This tractor did not have any of this hooked up, and no spring. The book shows a spring but I can't figure it out. Any help will be appreciated.
Leroy
03-03-2006 06:12:05
 Re: BF Model R Governor in reply to Dreydan, 03-02-2006 12:21:27
What model tractor do you actually have? There was no BF model R tractor. Moline made the BF that was the old Avery R and the Moline R, two completly different type of tractors. So is it a Moline BF or Avery R that had a foot clutch or is it the Moline R that had a hand clutch? With incorect information most people will just skip post.
Kelvin
03-03-2006 09:13:12
 Re: BF Model R Governor in reply to Leroy, 03-03-2006 06:12:05
Actually, there was a BF Avery model R. it was replaced by the MM BF when MM bought the B.F. Avery company. The major difference I have seen between BF Avery Rs and MM BFs is the BF uses the Unimatic hydraulic system, while the R uses the self-contained unit,with control valve/cylinder/reservoir in one housing.
The engines are about identical. I can tell you that there is a link from the uppermost arm on the governor housing back to the carburetor. The lower lever hooks to the throttle cable from the lever on the steering post. It uses a fairly heavy governor spring.
The I&T manuals I have consulted don't have a good illustration of the governor assembly.
It might be a good idea to remove the governor assembly and make sure it looks like it is O.K. There was probably a reason that it was bypassed.
Also, these governors (At least the governor used on V models-the R may be somewhat different) are very particular about end play of the main shaft.
dreydan
03-03-2006 12:41:29
 Re: BF Model R Governor in reply to Kelvin, 03-03-2006 09:13:12
Looking at the I T manual the governor that is on the motor looks to be the novi, when purchasing the tractor is was taken apart in many pieces and I am not sure how the linkage on the governor hooks up or if I have all the pieces
on most governors they have a spring this looks like is was hooked up solid
Kelvin
03-03-2006 17:39:42
 Re: BF Model R Governor in reply to dreydan, 03-03-2006 12:41:29
You say the spring looks like it was 'hooked up solid'. Do you mean there was no external spring from the lower lever to the upper lever? Was there some kind of homemade link in its place?
I'm guessing that you mean outside the housing the top end of the spring hooks onto the lever that works the link to the carburetor and the lower end of the spring hooks to the lever that is operated by the cable from the hand throttle on the steering post.
All of my experience is on the governor used in the V models, they use laminated flyweights, not ball bearings.
We have a BG (1 row version of the BF) but the governor has never given trouble. On the V I worked on, there was no internal spring like there is inside of most governors. That external spring is the only spring there is in these governors. It pulls against the pressure created by the flyweights or balls inside the housing.
