Minneapolis Moline Tractors Discussion Forum
Jet star # ampli torque
Brian Peppler
03-02-2006 06:21:05
I just repaired the torque on a Jet Star 3 1964 model new needle bearing and all the small rollers,springs,clips in the clutch when I started the tractor up and let it warm up for 15 min. I moved the torque lever to low and it started bogging the motor down with out the tractor in gear. What could be the problem. It all went in very good and I made sure the clutch with the rollers, springs,clips, went one way but not he other and all the items were installed right. HELP Thank you,
Ks-farmer
03-03-2006 20:44:08
 Re: Jet star # ampli torque in reply to Brian Peppler, 03-02-2006 06:21:05
Did you put the sprag clutch in backwards?
