Minneapolis Moline Tractors Discussion Forum
need to replace heads on a UB
sammy g
02-28-2006 06:36:01
Have a UB with cracked 4210 heads, It has a G crank, 6" stroke with a 4 7/8 bore. Can you tell me what I can replace the 4210 with? thanks
ejr-IA.
02-28-2006 10:26:45
 Re: need to replace heads on a UB in reply to sammy g, 02-28-2006 06:36:01
You could go to a square port head off a later model 10a4232 or round port 4206 which is higher compression than the 4210 and 4207 which is higher yet.Nothing wrong with the 4210 these where used for most of the lp engines ,little more compression than the gas head.
