Minneapolis Moline Tractors Discussion Forum
Type G Closed Center convert to load sense
Molinekid
02-28-2006 05:04:23
I am contemplating changing the compensator from high pressure stand-by to a load sense compensator (where the pump would drop down in pressure then kick up to full psi when demanded) just as the modern tractors of today would have. Just curious if anyone has done it or knows the right kind of personel to contact. I know old moline dealers would have a guy screw the compensator way out when hydraulics not needed, then turn back in when use needed. This tractor doesn't have a hyd cooler, and power steering off of separate open center pump. Seems as all would be needed is some sort of flow device with load sense line.. plus the other compensator.
Eric Berglund
04-17-2006 22:30:59
 Re: Type G Closed Center convert to load sense in reply to Molinekid, 02-28-2006 05:04:23
Just wanted to know if you found a solution to this problem .
I have a similar application and would like to know if you solved it
