Minneapolis Moline Tractors Discussion Forum
A4T-1600 overhaul
Eric Berglund
02-26-2006 23:04:17
Hello All!
I just fired up a 585 MM I rebuilt and I have it mounted on a test stand. It developes 50 psi oil pressure at an engine temperature of 175 degrees F and running at about 1800 rpm.At idle the oil pressure drops down to about 45 psi. I am running the internal oil pump that has pressure adjustment by means of adding/removing shim washers from under a relief spring of the oil pump.Based on the fact that the pressure can be increased by about 3 psi per shim , should I add one shim? or should I just leave it alone? My book says that it should have 50/55 psi at operating speed and operating temperature. I am using 15W-40 oil. Any opinions would be sincearly appreciated
