Minneapolis Moline Tractors Discussion Forum
power adjust wheels
lakeport rob
02-21-2006 17:44:43
will 28" 4 bar power adjust rims from a massey ferg or allis work on a MM 445. i understand that the inner rim probably will have a different bolt pattern. thanks
1755
02-28-2006 15:33:41
 Re: power adjust wheels in reply to lakeport rob, 02-21-2006 17:44:43
If the number of rails are the same and they look like the same sise and angel in the way they are welded in I think it is worth a shot I dont think there where to many diferant ones try the rim on yours befor you mount the tire to be sher you might be abel to crosreferance the numbers in a after market parts cadalog
Kelvin
02-22-2006 09:10:50
Rob,
I think they will work, but I don't know for sure. 335 utility use the same wheel as an Allis C, center and all.
I think if the center disk is 8 lug and uses 9/16 lug bolts the whole assembly will fit.
Some Fords use 5/8" or larger lug bolts/studs. I don't know about Massey.
