Minneapolis Moline Tractors Discussion Forum
F-M K4B
dlp
02-21-2006 11:51:38
Can anyone tell me where the timing marks are on the two gears inside the mag? There isn't two bevel edges on the fiber gear.
Glen in TX
02-21-2006 12:53:47
 Re: F-M K4B in reply to dlp, 02-21-2006 11:51:38
The fibre gear should have some marks "A" for anti-clockwise CCW rotation and "C" for clockwise CW. The rotation of the mag is determined by facing the impulse drive end and which way it turns when tripping the impulse. For CW mag line up the C mark on RH side of top corner of bearing plate while the cam is in a vertical position with high part being up and down. If the marks are gone you'll have to match it with a new gear with marks. For CCW align the A mark to top corner of bearing plate with cam vertical. K mags that have had O,OH, OR parts installed may have beveled teeth or other marks and align differently.
dlp
02-22-2006 16:23:45
 Re: F-M K4B in reply to Glen in TX, 02-21-2006 12:53:47
Which way is the rotation for a MMZ?
Glen in TX
02-22-2006 17:05:14
 Re: F-M K4B in reply to dlp, 02-22-2006 16:23:45
"CW" clockwise so use the "C" mark.
Glen in TX
02-21-2006 12:52:44
The fibre gear should have some marks "A" for anti-clockwise CCW rotation and "C" for clockwise CW. The rotation of the mag is determined by facing the impulse drive end and which way it turns when tripping the impulse. For CW mag line up the C mark on RH side of top corner of bearing plate while the cam is in a vertical position with high part being up and down. If the marks are gone you'll have to match it with a new gear with marks. K mags that have had O,OH, OR parts installed may have beveled teeth or other marks and align differently.
