Minneapolis Moline Tractors Discussion Forum
G706 front axle seals
Cravin
02-15-2006 17:47:13
Where can I find front seals/boots for front axle of a G706. Also would like to know if there was just one axle type used or several different types? any info appreciated.
Brad Konrath
02-15-2006 20:38:15
 Re: G706 front axle seals in reply to Cravin, 02-15-2006 17:47:13
I went through this last summer. There are two different axles that were used though a coleman and an elwood. The coleman axle is the one that has the rubber boots and I believe the elwood is a completely different system. IH used the coleman axle on some of their tractors and that is how I sourced the parts. If you have a CIH dealer near you have them look up the 1206 with the FWA and the axles are the same. I believe I still have the part# written down somewhere and will post it here if I can find it. I do have the part# for the grease seal which should at least get the CIH dealer looking at the correct drawing, it is 259263C1. It would probably also be helpful to take your parts manual along if you have one so you can compare the drawings. Hopefully this helps you out.
Brad
