Minneapolis Moline Tractors Discussion Forum
Fence post removal
F 250
02-14-2006 13:23:05
Whats the easiest way?
Tuck
02-19-2006 20:01:36
 Re: Fence post removal in reply to F 250, 02-14-2006 13:23:05
Cut a sharp edged hole in a heavy steel plate big enough to drop over the top of the post. Tie it to your hydraulic loader bucket with a short chain so that the tilt of the bucket will make it lie flat to open the hole and drop over the post. then lower the bucket and plate over the post. Next tlit the bucket forward so that the plate hangs on the cahin and the sharp edges contact the post. Raise the loader boom and out comes the post. No getting on and off and no wrapping tying the chain. Works on wood and steel. I actually made mine out of junk auto independent suspension front end frame....almost ready made. You may need 2 short cahins tokeep your plate flat from side to side. You will need to experiment a bit for best lash up to the loader but it works like a charm, fast easy, one man...or woman
ILL John
02-14-2006 18:31:11
IF you don't have a loader or 3 point, take a chain, wrap it around the post, put it over the dropped center of a car tire rim, hook it to your tractor and puller out!!
F 250
02-14-2006 18:12:02
Hey Rascal, Dyou have any ideas on how to remove fence posts?
rascal
02-16-2006 15:10:53
 Re: Fence post removal in reply to F 250, 02-14-2006 18:12:02
Hey Bencie if you start your F-250 and get out and don't set your brake that will work...
Phil Hengesbach
02-14-2006 17:02:49
I wrap a chain around the boom on our loader then you wrap the other end around the post. If you are by yourself it takes longer to get on and off the tractor than it takes to pull the post.
old
02-14-2006 15:36:57
What type of posts, wood or T posts. If its T posts they make a tool just for doing that. Also loaders and 3 point do a quick easy job of pulling them also
BCnT
02-14-2006 15:04:06
i pulled up over 1000 cedar and tee posts last winter with my ford 2000 and a home made a-frame on 3 point...hardest part is all that getting on and off tractor hooking up sling...alot easier with 2 people.
Ken Crisman
02-14-2006 13:45:51
That's what's nice about the 3 point on Ford tractors . I've also pulled my truck with snowplow hoist still on the front up to a post . Hook a sling or chain around the post & it usually comes up a little at a time , then rehook it . I've had a few tough ones . Good luck . Ken
1755
02-27-2006 18:49:21
 Re: Fence post removal in reply to Ken Crisman, 02-14-2006 13:45:51
I found that a clevis hook will drop down a steel post and hook a chain in the hook and lift with loader ,3pt or handy man jack works grate I have seen them in farm stores
