Minneapolis Moline Tractors Discussion Forum
G900 mains and rear seal
Curt Cooke
02-06-2006 11:08:18
Has anybody out there actually replaced the main bearings and/or rear crankshaft seal while the crank was still in the block. If so, how much trouble am I asking for. I don't like the idea of attempting to push felt around the crank.
Chuck S.
02-06-2006 15:47:56
 Re: G900 mains and rear seal in reply to Curt Cooke, 02-06-2006 11:08:18
Not as hard as it sounds. Get a rear main seal removal /install tool kit. TO remove the seal you will use what looks like a screw with an eye. Screw tool into seal ahn pull while turning crank in direction of rotation. { NOTE MM ENGINES WILL ONLY TURN ONE WAY BECAUSE OF A/T OVER RUNNING CLUTCH.} Use bottem half of main to pre shape seal. Use seal pulling that looks like a cable with a grab loop and pull it in, while turning the crank. Dont trim seal until it is in bcause tool will damage where you place loop. Glue bottem half in place. Ps lossen the main bolts this alows the crank to drop a bit. The brg,s you push out by using a screw driver or by placeing a brass screw in the oil galley hole of the crank and turning it. GOOD LUCK.
F M-M
02-07-2006 19:37:20
 Re: G900 mains and rear seal in reply to Chuck S., 02-06-2006 15:47:56
Where can you buy those tools that you are speaking of? I need to do a couple of 1000s and I have made do in the past with some crude devices. This sounds much easier.
Chuck S.
02-08-2006 17:01:23
 Re: G900 mains and rear seal in reply to F M-M, 02-07-2006 19:37:20
We got mine thru NAPA.
