Minneapolis Moline Tractors Discussion Forum
MM G706 Belt Pulley Drive
SWMolines
02-01-2006 07:23:23
Will the belt pulley drive from a UTU work on a G 706? I'd like to set my 706 up to run a Baker Fan at our next club show and have a belt set-up for a UTU that I believe will work on the 706. But, I'd like to know for certain before I start draining fluids and pulling parts.
Thanks!
Curt Cooke
02-02-2006 06:23:35
 Re: MM G706 Belt Pulley Drive in reply to SWMolines, 02-01-2006 07:23:23
SW, I have transplanted a UB pulley drive in my 705. It's the same. Just in case you ever need to know, the PTO on my 705 came off a G, the PTO on my 97 Massey came off a UB. There's no problem.
Curt
Denny H
02-01-2006 19:47:12
I have did this on a G-VI use one from aUB this has a lever to shift pulley in & out I would think the gearing should be the same inside the trans
Bill Becker
02-01-2006 11:09:49
I was wondering the same thing with an M602. will a "U" belt pulley bolt in?
Jeff Zabel
02-01-2006 10:17:41
I have the parts you need,all but pullie. Will trade for M/M parts, like GB starter or other things.UB NUTS Wis.
ejr-IA.
02-01-2006 10:04:05
Looking in a shop manual they look the same.Does it have the shifting lever on the belt pulley housing?
SWMolines
02-01-2006 12:07:41
 Re: MM G706 Belt Pulley Drive in reply to ejr-IA., 02-01-2006 10:04:05
You are probably looking at the same manuals I am. But, I do not have a parts maunal for both tractors. If I did, the parts numbers are likely not going to match but that does not mean the Belt Pulley drive will not interchange.
I am guessing I would not be the first to attemp this trans-plant and want to hear from someone who has beeen there done that.
Joe Leising
02-01-2006 18:24:36
 Re: MM G706 Belt Pulley Drive in reply to SWMolines, 02-01-2006 12:07:41
There aren't that many bolts to deal with, so I would just park them both on a pretty step hill. Let them sit a day or so, and the gear oil should drain back enough that you should be able to swap stuff around and not make too big a mess. Let us know what you find out.
Joe
SWMolines
02-02-2006 05:38:34
 Re: MM G706 Belt Pulley Drive in reply to Joe Leising, 02-01-2006 18:24:36
Hi Joe!
I talked to a couple of people on the phone last night and they said MM did not change the pulley drives when they came out with the 705/706. So, I will be performing the swap shortly if the Baker Fan is available at the Mid-February show.
It is hard to give a 706 a good work out when you only own 1 acre of land on the out skirts of town.
Dave Ritenburgh
02-02-2006 07:21:55
 Re: MM G706 Belt Pulley Drive in reply to SWMolines, 02-02-2006 05:38:34
You could just drag a couple of 2 star crawlers around behind your G706 and I would think That could make it snort a little.
SWMolines
02-02-2006 08:25:22
 Re: MM G706 Belt Pulley Drive in reply to Dave Ritenburgh, 02-02-2006 07:21:55
Hi David!
The nieghbors might not like the dust I'd kick up. However, there is a pretty steep hill not too far away I can run it on if the Baker Fan option does not work out.
I thought I might have to use the 706 to get the 2 Star Loader into the shop. The 5 Star and 670 both found it a little difficult to tow it in the soft soil.
