Minneapolis Moline Tractors Discussion Forum
GTB Rear Wheels
Turtle Gears
01-30-2006 17:42:51
Needing to find out what pressed-steel wheel will fit my 49 GTB MM it has heavy centers write know. 8 hole bolt pattern&13inch center hole. Thanks T.G.
Jeff Zabel
01-30-2006 22:00:37
 Re: GTB Rear Wheels in reply to Turtle Gears, 01-30-2006 17:42:51
I have a 1955 GB, if it has the same hubs as your"s. You can remove them and take them too a machine shop and they can turn them down too fit a nine hole rim. I went to a salavage yard an found a 7700 JD combine rim too be real close. Icut out the center too macth my hubs an then drilled my 8 holes fore the bolts. I have 30-5 32 super all traition Fire Stone,s on my GB.
Jerry Cent. Mi.
01-31-2006 04:34:10
 Re: GTB Rear Wheels in reply to Jeff Zabel, 01-30-2006 22:00:37
I have the same problem. I now have a flat 5/16 thick plate welded to the rims that works very good but will not interchange with the 9 hole rims on my other tractors. I thought of reversing my hubs and having the back sides turned to fit the 9 hole rims.
