Minneapolis Moline Tractors Discussion Forum
M5 piston rings
Sponz
01-27-2006 12:35:32
Im overhauling a M5 and i believe its bored .040 over, but i cant locate rings for it anywhere. i have all the gaskets i need so far all i have left is main bearings and piston rings.. i havent tried to get the main bearings..i think i can get those but i need help with the rings..
Thanks guys
Sponz
Captainhookerus
01-27-2006 15:57:38
 Re: M5 piston rings in reply to Sponz, 01-27-2006 12:35:32
Agco part # is 20v7100753 for.040 rings. You may have better luck buying a set of Main brgs for a 6 cylinder. They are the same except you will have an extra intermediate. Sometimes an after market 6 cyl set is cheaper than a 4 cyl set
BG1
01-27-2006 14:56:02
Sponz,
Check out www.hastingsmfg.com
Click on their catalogs. You can try contacting them to find out if .040 o/s rings are available. I would think they would be.
Brian
