Minneapolis Moline Tractors Discussion Forum
445 3pt capacity
PaulMIL
01-27-2006 05:25:52
I"m trying to find the capacity of the 3pt lift on a 445 utility, its a cat 2 and looks heavy duty, it has the pullout extensions on the arms. The manuals don"t show the cap nor does tractor data.com. Thanks,
Paul
Gregg in ohio
01-27-2006 16:55:59
 Re: 445 3pt capacity in reply to PaulMIL, 01-27-2006 05:25:52
Gee i dunno either..all i know is that under the seat is a rectangle plate with 4 bolts on it and you fill this up till its about a inch from the opening.it where the spool valves are.mine would have a diff cap than yours i have the mm loader thus alittle more fluid..ill do some digging and try to find it..gregg
PaulMIL
01-28-2006 17:56:09
 Re: 445 3pt capacity in reply to Gregg in ohio, 01-27-2006 16:55:59
I should have been clearer in my question, just wondering if anyone knew the weight capacity of the 3pt on a 445 utility would be. I"m guessing around 2,000lbs but didn"t want to overload it.
Paul,
Kelvin
01-27-2006 18:55:10
Its in the neighborhood of 3 gallons.
