Minneapolis Moline Tractors Discussion Forum
Bearing numbers help
Richard McNiff
01-25-2006 18:59:49
I am posting some bearing numbers fron the Minnie parts book and hope that someone can help me find them. A "JT9202" Roller and cone assembly and a "JT9201" cup for Roller and cone. These are in the front steering housing for an RTU. I could also use a "JT328" Oil retainer for Adjusting plug. Any help with these numbers would be greatly appreciated. Thanks for a great forum.
"poor" Rich in Nebr
richard McNiff
01-26-2006 19:33:32
 Re: Bearing numbers help in reply to Richard McNiff, 01-25-2006 18:59:49
Thanks for the info. I will print the page off and try the parts store. May God Bless and keep you well.
"Poor" Rich in Nebr
Kevin Moschenrose
01-26-2006 22:08:09
 Re: Bearing numbers help in reply to richard McNiff, 01-26-2006 19:33:32
I have found on a couple of different times that like any printed material there maybe a flaw in the numbers. I also did get your email to me but my junk email filter caught it so the next time you need help it won't do that. Good luck with it.
Kevin Moschenrose
01-26-2006 09:02:36
Okay I will do the easy one first! The seal JT328 crosses to these newer numbers and supercedes the older one and then I took those numbers and crossed them to seal books that I do have.
JT328 to: 11a5774
11a5774 to: 20-0009154 ="new white number"
20-0009154 to 71x7055 Garlock or 78x9994 Persion seal "owned by the same company"
71x7055,& 78x9994 to: 9997 CR "chicago Rawhide"
The bearings are a different story. MM brakes the race"cup" down as a part number and then the bearing itself. That is where trouble begins. Most manufactures any more on that small of a bearing sell both pieces as one whole unit therefore giving it only one number. But this is what I came up with. Using my MM hotline and MM cross reference books forward and reverse 1986 versions.
JT9201 to 32c "No name given Timken I think".
JT9202 to 31bc " Same here as well Timken?"
Both of these supersedes to a newer number in my books and as one part number as well both parts.
JT9201 & JT9202 move to a set number "both pieces" to JT2326.
JT2326 to: 10R429
10R429 to:10A8754
10A8754 to: BE733 or BE733a "Bower/BCA"
This also crosses to 1013185m1 with which I have no idea what bearing manufacture that is. It also moves to two different "GM" numbers of GM103898 & GM172592. GM numbers are General Merchandise and those are generic numbers that MM gives to a part that they may buy from more than one manufacture. Example of that is: A hundered different seals in aparts bin together on the "GM" number some maybe CR, some maybe national, or stemco. All fitting the same housing or shaft or what ever. I hope this helps. If not I can go deeper by calling a bearing house near me.
Kelvin
01-25-2006 19:32:41
These are the bearings I told you were tough to find and expensive to buy.
The bearing numbers don't show up in the 1965 substitution list.
The seal JT328 is substituted by 11A5774. That is still a Minneapolis Moline #. It does not show up in my National Oil Seals master interchange catalog.
What I suggest is to mike your shaft where the seal goes and to mike the I.D. of the hole and order a National oil seal to fit.
