Minneapolis Moline Tractors Discussion Forum
marvel carb for rtu
ps
01-22-2006 15:26:22
I need tofind out what other tractor uses the carberator from a rtu,does the ford carbs fit? like off a 9 - n or some thing else? the one I have is cracked,and the needle threads are shot. thanks ps
Kelvin
01-24-2006 08:59:01
 Re: marvel carb for rtu in reply to ps, 01-22-2006 15:26:22
I tried a carb from a Ford Jubilee (133 cu in?) on my R (165 cu. in.) and it would not idle properly. It seemed to run fine at load. I also had to slot the holes in the manifold to get it to fit.
My reccommendation is to either find the right carb or fix yours, using somebody else's good parts.
Augie
01-23-2006 10:02:37
Is that a TSX-36? I've got one that could donate the top half, power nozzle is busted off in the bowl. Wouldn't take much $$$ for me to part with it.
ps
01-23-2006 04:56:51
i would but the cast housing is broken and the thread for the main jet are rusted away thanks pete
Tim'sMM
01-23-2006 05:25:16
 Re: marvel carb for rtu in reply to ps, 01-23-2006 04:56:51
I sent Motec one with a broken top and they replaced it for the same amount.
old
01-22-2006 18:36:46
Why not buy a rebuilt carb from this site and or Valve----- --bilt. V-B has them for around $270 and that way you will have what should be on it
ILL John
01-22-2006 19:26:09
 Re: marvel carb for rtu in reply to old, 01-22-2006 18:36:46
Why not send it to Matt @ Motec Engineering, he'll rebuild it for $75.00!!! He does quality work, tests every one, and the price is VERY reasonable. email me if frustrated or confused, John
