Minneapolis Moline Tractors Discussion Forum
Head Change (Compression Problems?)
Fungus
01-20-2006 09:52:19
I would like to put a sinlge cast head off of an old U on my KTA. I was wondering if I will run into any glitches with compression after making the switch? The U's head is a High Compression head while the KTA I believe, is not, as it can burn kerosene and gas. Here's the casting numbers. Any help would be great.
New Head (Model U)
KE 282D
Old Head (Model KTA)
KE 282
Tom in Vic
01-26-2006 19:43:44
 Re: Head Change (Compression Problems?) in reply to Fungus, 01-20-2006 09:52:19
The LP head would have a larger combustion chamber therefore lower compression ratio.
Will probably run on petrol but have fewer horses.
Harrold Rhodes
01-21-2006 09:23:55
I think if you go to the LP head you might have to change push rods.
Fungus
01-23-2006 09:23:58
 Re: Head Change (Compression Problems?) in reply to Harrold Rhodes, 01-21-2006 09:23:55
Is there an easy way to tell if it's an LP head I purchased or if it's simply gas?
Mopower
01-20-2006 12:40:36
You should have no problem whatsoever. H-C gas heads back then were only about 5.5:1 ratio approx. Even if you found a rare 1940s single cast LP head, it would be just fine on pump gas these days. You might gain a little power.
Fungus
01-23-2006 09:22:20
 Re: Head Change (Compression Problems?) in reply to Mopower, 01-20-2006 12:40:36
Is there an easy wasy to tell if it's an LP head that I purchased or just gas?
Mopower
01-23-2006 09:36:54
 Re: Head Change (Compression Problems?) in reply to Fungus, 01-23-2006 09:22:20
I've never seen an LP head but I suppose the part number would have a different letter after it. I'll ask around and find out what a gas or LP calls for.
