 Our FFA chapter has recently had a Moline 445 donated. It was locked up, we have got everything freed up and all looks pretty good. We're going to be in need of some items, if you all could point me in the right direction as to where to get the following things, it would be greatly appreciated. Rod Bearings - .010 undersized Piston Rings - (Not sure on bore yet STD, .010, .020, or .030) Gasket Kit - In Frame Kit (VC, Head, side cover, manifold, etc...) Front Main Seal - ?? Other questions - This is a gas motor, is it 206 cid? What other Moline tractors share the same motor? I'm getting an I&T manual, and we're getting some matched rear rubber this week. Can the front main seal be changed in frame? Can the crank be removed while in frame? This is the first Moline that we have EVER worked on, and so far, it seems even easier than the Farmall H's and M's that are common in our area. Right now, pistons, rods, cam, heads and Valvetrain are removed and getting cleaned. The rod bearings were a little scorched, so we are replacing them. I'm excited to get this tractor running again, it has a 3 pt hitch and will make a really nice tractor. I'll probably be able to answer some of these questions on my own after I get the I&T manual. Thanks for any help you can provide! Jared Jeffries Jasper FFA Advisor
