Minneapolis Moline Tractors Discussion Forum
445 getting it runnig again
cole rogers
01-16-2006 17:13:46
my 445 was running absoulutely good then i gave it alot of throotle the it whent dead can you you help me new coil and rebuilt starter whas put on a motnth ago
cole rogers
01-19-2006 13:23:57
 Re: 445 getting it runnig again in reply to cole rogers, 01-16-2006 17:13:46
well i jumped it off since the battery was dead ho do i do that firing order thing thanks for all your help
John No Mi
01-18-2006 13:49:52
The firing order is 1-3-4-2
reply to get iit running
01-17-2006 18:07:50
i tried it this affternoon it had some stuff but down here in south ms it is raining so water got in it i am afraid i tried so much yesterday that i ran my battery down so when it dries up i am going to try pulling it off with the truck i removed one of the spark plug caps and got the first two mixed up so can yall help me
John No Mi
01-16-2006 19:07:13
The sediment bowl is located on the right side of the tractor behind the side curtain at the bottom of the gas tank. About 18 inches to the rear from the carb. Shut the gas valve and then loosen the knob in the bail to remove the glass bowl.
answer to 445 question
01-16-2006 18:07:36
hey greg what is thesediment bow and where is it at
FRANK JOHNSON
01-16-2006 17:58:54
Hey Cole, the MM 206 engine is a good engine. Check that the distributor is spinning, then check that it is firing on time, make sure you are getting a completed ground through your point contacts, make sure you have power voltage from your switch to the coil, then check that you are getting a ground signal from your points to the negitive side of the coil. Check your ditributor cap and rotor button for problems. If you find your distributor is not spinning then the oil pump drive shaft coupler may have sheered the roll pin. Good luck
Gregg in ohio
01-16-2006 17:57:51
Check for spark...i bet you have sucked a bunch of crud into the sediment bowl..mine was full of some balckish looking crap causing it to run rough at half or better throttle..gave her a bgood cleaning and fixed it..let us know what goes ..gregg
